SM465 question
I have what we thought was an SM465. Stamped " 10 " "GM" and this serial number "8273212"
After drilling and tapping the input shaft in preporation to connect it to the 3 speed transfer case, we tried to slip a gear onto it and it wouldn't go. Both are 10 spline, but splines look to be a slightly different offset pattern. Another "SM465" in the shop took the same gear with no problem, so problem is with the spline pattern on this "SM465". Anyone ever run into a problem like this? Anyone have a suggestion for a fix, short of pulling the shaft and replacing it.
thanks
troy
I just ran at lunch to a shop here in town that does tons of 465's. They looked at it and said the differences were a case of the splines being worn thin and the torque bending the splines over slightly changing the pattern enough to stop the gear from slipping on. The wear was so clean and uniform it looked almost machined to get it that way. So, need to swap in a new shaft or an old one in better shape.
thanks
troy
Bummer Troy, you might try using a file. Once you get it on I think you should be fine even if the spline ends are all buggered up... Definetely make sure you prep and collect shavings/dust though. Might be a quick and easy way out of a more complicated ordeal...
Splines really appear thinner than normal, If I ground them off more to allow the gear to slip on I wonder if it would fit with a little slop, maybe too loose, more prone to breakage. I think I would be better off to spend the money to replace the shaft. And while the shaft is off it would be much easier to drill and tap that end this time
troy
troy
For what its worth, the effort required to replace that shaft is the same necessary to replace the bearings and synchros. If the output shaft is buggered, lord knows how well the rest of the internals fared. The differance is the cost of the parts for the most part.
Also, Classic Cruisers sells the output shaft that has been drilled and tapped.
agree with ige....whole tranny may run ya $50-75....shaft alone from CC is (was) $125, stock shaft plus bearing kit won't be cheap either.....
Yes that was me. I was trying to improve my gas mileage by drafting closely behind that Tundra ;-) Did you notice the nice new undercoating on the rocker panels? I was trying to look as good as I could on the end of the strap.
The cruiser is in our Toyota Master Techs hands now.
troy
troy
No I only noticed you coming through 17th South.
Ah Master Will...or Scott?!? ;)
Little hijacking here. I have a 465 but I can't find a dust cover that covers the flywheel. Anybody have one laying around or know where I could find one?
Thanks
