sm 465
landcrusher909
Athlete/Race truck driver/Hobbyist
GOLD Star
Southern Calif.
just picked up my sm 465 10 spline it came out of a blazer and with that said things are coming together , after the first of the year i will start picking up everything else i need thanks to the tech link .My truck is a 73 fj-40 stock 6 while i am getting all this together if anyone has any suggestions or opinions feel free to let me know what u think . I want to have everything together for moab
landcrusher909 said:
went thru mike davidsons write up and he gave me alot of insight..
Mikes write up is VERY informative...I would go through it again...and again...
... looking at buying the plate from woody
This is also a really good idea....they are really nice.
Good luck!
-Steve
Let me post up a little of what I found when I put mine together. I don't know how this compares to the writeup, but here goes: I've got a 2F-SM465-NP203-3spd TC setup. I got a 3spd bellhousing and got it milled to accept the Chevy input bearing retainer ($60). Some people get the retainer turned on a lathe, but I think you need to run socket cap screws (for the smaller head) and I figured it was just easier not to deal with it.
I got a pilot bushing from AA. You will find that the stock pilot bearing fits over the 465 input, BUT since the 465 input is shorter than the Cruiser 4spd (should be the same as the 3spd tranny, I think), you need the deeper bushing that AA has ($35). I measured it, intending to look up something comparable and maybe cheaper, but didn't get around to it yet. Clutch disc is for a Chevy ($35 or so). My Cruiser disc didn't fit the 465 input, but I think I've read that it fits for some people. The spline shape should be different.
Pressure plate, throwout bearing, and clutch fork are 4spd. Now one thing I had a bunch of trouble with was the fork pivot pin. I kept trying different combinations of TO bearings, pressure plates, forks, until I realized that I was using the wrong pivot pin. One is shorter than the other (oops, can't remember which!) - I think I ended up using the 4spd pin. If your assembly has no play in it, it's wrong, and this is probably why. I don't think I've ever seen anyone mention it in person or in writing. I scratched my head like a dumbass for days over this until I figured it out.
You also need to sleeve the nose of the SM465 bearing retainer to accommodate the larger IDed 4spd TO bearing. I took a piece of exhaust tubing of the appropriate thickness, cut it to length, then cut a longways chunk out of it. If you looked at it from the end it would have been a C-shape. Then I stuck it on the nose of the retainer, cinched it tight with hose clamps, and welded it to the nose. You can also buy the entire input bearing retainer from AA, I think - maybe around $150 or so? I can't remember. In that case I don't think you have to mod the retainer or bell at all.
Hope that helps. Someone correct me if I'm wrong. At this fine hour, everything sounds good....
Oh yeah, this hasn't been run on the road yet, just around the yard. A bunch of this was just me figuring out how it looked like it should go together. Works so far....
-Tyler
BCA Federal Mogul bearing
202-RRE
This is the pilot bearing that I have used. It is a bearing, like the Toyota unit, only it has a longer inner sleeve to mate up to the input shaft of the shorter Chev tranny.
The Chev disc will fit the Toyota trans input shaft....when using a Chev tranny, you need to use a Chev disc....at least that has what I have found on the 420 and 465 installs that I have done over the years...
Good luck!
-Steve
