sm-420
What is the differance between a 420 with the ribs and one without? I have both and need to know which to build on. The one without ribs is out of a two-ton c-65 but it is set-up for a 14" clutch and has a large input shaft and the bearing retainer is missing. The other is a core and is pretty much there,but needs to be gone thru.
it has been a while since i looked into the SM's this page has the difference between the years about half way down the page....should tell you whatever you need to know, dunno which one you should build but hopfully this will help
http://www.novak-adapt.com/knowledge/sm420.htm
any plans on selling the other at some point?
The one you want to keep has the seal instead of the oil slinger on the input shaft, I think the later versions had the ribs, the Novak kit has the parts for both the heavier and the lighter tranny, the heavier one has a larger syncro for 2nd gear and heavier front bearing on the idler shaft as well, if you are using a plate adapter like Extreem Bends you will need to grind the retainer bolts and the washer that holds the idler shaft in place in the rear of the tranny, the lighter version uses a snap ring, if I were doing it again I would use the lighter version so there were less mods to use the adapter. Cheers, Larry
Thanks for the replys, I will be tearing down both to see what I have or need and to see if the ribbed one has the seal [my luck it won't]. My biggest concern is the later one I got as a core and I don't know why it was pulled out .Nothing so far is wrong or woreout on it. The two ton truck was in use until the owner junked it out. I might just use it with the 14" clutch it looks like I have the room for the bellhousing instead of my three speed bellhousing but it uses a rod type release.I don't know what it will take to put on the toyota system.
http://members.cox.net/cglabe1/SM420/sm420.html
Don't know if you hve seen this site but it's pretty good to review before putting in the SM420, hope the link works, if it dosen't just google sm420 it will come up, might be in the tech section as well, Cheers, Larry
