Sluggish when cold
Puerto Rico
Hey guys,
Maybe this is just the way of the beast but...
When I start up in the morning and do not let the LC warm up (I live in PR so it's pretty warm)... When I take off the LC is really sluggish, to the point where I press on the gas and it seems like its flooding... no power until I press harder on the gas and it seems to take off...
What I mean is that when pressing on the gas normally it just dont want to go and it behaves like when you are taking off in a wrong gear.
After it warms up two to three minutes everything seems like its back to normal. I adjuste the throttle cable and it helped a lot, but I'm still sluggish when cold. It feels like it's gona stall but it never has.
Would this be part of any choke system or maybe the injectors, even though my mechanic said he cleaned them a fgew months ago on my engine rebuild.
Could this have anything to do with a sticking valve on my tranny?
Any insight will be welcome... THANKS!
My mechanic jut told me to change or check the Coolant Temp Sensor to see if its sending the wrong info when cold... making the LC send less gas than needed...
This is a sensor I reused when doing the rebuild and might as well replace it?
Just to add some background info.... My engine was completly rebuilt.. but most sensors were reused... New plugs, cables, fuel filter, timming chain kit, head work, valve work, injectors cleaned, TB cleaned etc.. etc...
This problem was present before the rebuild but I was not that worried about it... but now that I rebuilt the engine it kinda bothers me.
LOL.... really?.... 55 views not one comment, opinion, insight not even a "Do a Search"..:hhmm:
OK?... I just got the he temp sensor, will install this weekend, will post up any changes.:flipoff2:
I had the same issue. 2 bottles of injector cleaner and letting it warm up a bit before driving seems to have helped. There were a few recommendations from other members including the throttle position sensor but I haven't gotten around to checking it yet. You can search "acceleration issues" and check out the few replies and recommendations I got.
Some random ideas: Possible injector issues? Worse case scenario is some coolant is slowly seeping into a cylinder overnight and wont fire correctly until it burns off - this would be the dreaded headgasket.
If it is only after sitting 8 hours or so, this could be it. If it sits for only a couple hours and still is relatively cold then fires up easily, it may be a sign that it takes some time for enough coolant to cause an issue.
Good luck and post up if you figure out what the cause turns out to be.
