Slow Wipers
I just tore apart, cleaned and lubed a used motor about the same age. I runs noticable faster than when I started on it. It's pretty straight forward, there are two small ball bearings of different sizes that fell out, they fit on each end of the motor shaft. The large plastic gear was darn near frozen in mine.
Brushes that have worn so bad that they are not pressed on to the shaft with enough strength. I got some alternator brushes and sanded them down to the right side and put them in. Sped up quite a bit.
