Slight overheating issue?
Hello fellow mudders...
so I was cruising in my stock 97 cruiser doing 75mph when I noticed the AC stopes blowing cold air. I noticed the temp gauge above the half mark ( didn't reach red area) and pulled over to a gas station where I noticed both top and bottom radiator hoses with more pressure than they should have. It's a CSF radiator that came with the truck and seems to be old.
No check engine lights.
She has 160k
Any hints of potential problem areas to look for?
search for threads on the subject. You will find info on fan clutches, radiators (and their caps), water pumps and belts, hoses, leaks, coolant levels, smoke out of tailpipe, bubbles in overflow, leak-down tests, compression tests, heater valves, and even catalytic converters if you delve deep enough. You didn't really give anything specific to work with other than subjective observations of hose pressure (unsure how that is determined) and an old appearing radiator so start from scratch, check the basics first (fluid level, visual inspection for leaks, etc. ) and go from there. Good luck
