Slight driver's side lean
Rigby, Idaho
I have a slight (3/8") height difference between my front driver's side and passenger's side wheels to the wheel well that causes a barely noticeable lean towards the driver's side. Any ideas what the cause may be? I'm not sure if it would be shocks or the springs. I bought my 80 with an OME lift and shocks with no idea how old any of the equipment is or when it was installed. It rides well enough but I'm wondering what to start budgeting for to correct the problem in the future. If pics are wanted, let me know of what. I didn't know what to shoot because, as I said, the lean is only slightly noticeable and I'm not sure I could capture it on camera.
It's called Cruiser lean, historically the recommended fix is a fat girlfriend!:hillbilly:
If it bothers you, there are trim packer spacers available. IIRC they come in 10mm or ~3/8".
I thought it could be related to an obese PO that always rode alone. :doh:
My buddy has a 60 he is having the same problem with. I notice it but he says he doesn't (I think he ignores it)
Let us know if you find the cause
If it's already got a name, it must be common enough not to be too big of a problem. My wife only weighs ~125, so that fix won't work unless I start buying her cake frosting for breakfast. Where is a good place to find these spacers? It only bugs me about once every 2 weeks or so when I notice it.
It does handle a bit squirrely at times but I assumed that was because the PO didn't do any caster correction when he did the lift. Is there a way to tell if the springs are on the wrong side?
That's funny, mine does the same thing (w/ the same OME lift)... maybe even a 1/2" lean / sag on the front driver's side... I was planning on swapping the front springs side to side and possibly add a shim to level it out. The back is perfect.
Here's a pic from when I first brought her home from Washington last year... you can see the lean...
when my rear springs were installed incorrectly, i had a very slight lean, but man, when driving, if i was cruising the highway and hit a slight dip in the road, the truck would jump to the right. almost change an entire line. it was scary.
didnt think it was the spring at first i thought shocks, sway bar issue, or something else.
turned out to be the rear springs.
Hmmmm. Would swapping/rotating all the springs benefit anything?
I'm only talking about swapping front springs side to side... then the drivers side would be the higher one, and when I'm inside, it'd be that much closer to level... makes sense to me. :hhmm:
That looks familiar. I guess I'm not alone.
I have the cruiser lean in the rear. Have not swapped the springs yet but will sometime soon.
Does not bother me that much, it comes with the territory.
