Slider Question...
Maryville, TN
Hey guys,
We're in the process of fabbing up my sliders, and I'm wondering what folks have found to be the best distance from the pinch weld to the outer edge of their outer tube? My thought is to kick the rear portion out to save the quarter panel, so roughly 12" at an upward angle from the pinch weld, which would put the outer edge slider wider than the outermost part of my tire. In the front, I'm considering slightly narrower, but I'm not sure yet. Anyone mind taking some measurements from the pinch weld of the body to the outer edges of your sliders, so I can get some ideas? I'd appreciate it...
Chris
I put the main body of my sliders directly under the pinch weld, then will use some round tube to do a kick out for rock protection. Not sure how far out I'll go with the tube yet, but it'll be far enough for it to be a step (to make the :princess: happy).
That measurement on my FOR sliders is 9". I've still got my flares so it helps somewhat to protect them, also. HTH
Edit: that's a straight (near level) measurement and same distance for the length of sliders.
One thing you may want to consider with the design of your sliders is if they stick out too far, you'll brush the back of your leg getting in an out. Maybe not a big deal for some, but since mine is a DD, I would find it annoying to keep getting dirt on the back of my pant legs.
I figured it was high time that I contributed some tech to this thread so I went out and measured my Metaltech sliders. The regular rail extends 7.5" from the pinch weld, and the rear kickout is 8.5". HTH!
Good point, but OEM running boards hung out approx same as flares, roughly 9" from pinch welds. You can step on the slider or running board instead of sliding your leg on it. I've learned to do that since I put mine on 'cause I also put the non-skid skateboard tape on the top of the slider and it tends to be abrasive on your pants if you drag them while getting out.
My outer tube is 7" away from the p weld in the front and 9,5" in the rear. The outer tube is tapered and sticks out past the rear tire roughly 1" at the widest point. The outer tube is set back on the main slider 10" at the front.
I can stand on the outer tube to reach the roof easily and the "kickout" makes for easy 3rd row entry.
D
Looks good. I decided after all the comments to bring the outer tube out flush with the outer edge of my tires and incorporate tube fenders into it and attaching them to the front and rear bumpers. We'll see if we can get it done tomorrow.
Chris
Did you buy or fab your own sliders?
