Slee part time kit
CreeperSleeper
Cascade Cruisers
Canby, OR
Before I get flamed, I did call Slee and the person I talked to could remember and didn't have it in stock to look at it. I need to know if the hub spacers come with the part-time kit or with the hubs themselves. I'm running Longfeilds, so I need to run Asian hubs with Longs gears in it. I would like know know if I need to source the spacers seperately or if it comes with the P/T kit without hubs.
Chad,
I can't answer your question as I am still educating myself about this mod. I think it would be nice to save some wear and tear on the front end.
What is your primary reason of doing this mod?
Well, when the lease is up on my DD, I will start driving my 80 daily. Chromo birfs (like my Longs) wear out really fast, so I'm doing it to save my birfs. I'm actually going to miss my AWD, but this will be better in the long run money wise.
I have the part time conversion on my 45 and no spacers came with the kit that will allow Asian hubs unless someone has made changes to the kit or the Longfields. The axle stub is too long and bottoms on the end of the Asian hub. I am running the Warns with I am not a big fan of, but they have not broken yet. I have not tried the AVMs that come with a part time kit, but they are supposed to be a good hub also.
Chad, gary is right. Sorry were speaking about different spacers when we spoke on the phone.
The spacers that do come with the kit is shown in this picture.
Those sit on the outside of the hub and make sure the birfield does not move inwards. Are you talking about spacers that move the Aisin hub outwards? If you want to use the spacers that come with the kit with Aisin hubs you need to make sure that the stubshaft does not hit the dial on the back. The spacers does not take care of this. It will position the birfield correctly in the aisin hub.
Chad, I have the kit on mine if you need to take a look or anything.
I did an install of Aisins with my Long's. What you need to do it take the birf to a machine shop to cut another circlip groove to match the location of where the Aisins need the circlip. Attached is a thread of my install. Mine seems to fit with out hitting the back of the lockout cap. But even if it touches, Bobby said you could just machine a little of the end of the birf to make sure it fits. The real issue is the circlip location on the longs to allow the Aisin hub body to seat properly.
https://forum.ih8mud.com/80-series-tech/235634-longs-aisin-hubs-install.html
Good luck.
What you need to do is put a D60 up front with 38's and then do Mark's crawler rather than continuing to spend money on stock stuff that ultimately doesn't work for how you wheel.
But I digress. :flipoff2:
Thanks, Christo. That makes a bit more sence now! However, I'm still not sure if the spacers come with the P/T kit without hubs or not...
Thanks, Jason! I appriciate the offer... I'll let you know if I need to take you up on it.
Good luck.
Yeah, machine work is what I'm trying to avoid... It's starting to look like I don't have much of a choice!
If I was going to do all of that, it would at least be running 40's! :flipoff2:
You could just sell me your longs and be done with it. :D
I think the spacers Creeper is talking about were like wheel spacers, in that they bolted under the Aisin hub body to space the hub out from the actual "hub" to get the circlip right and not hit the cap.
Looking at the pictures, I don not see these spacers. Seems the aussy hubs are made longer possibly to solve this issue, or they won't fit a long at all, don't know.
These would be easy to have made. If you know the difference in length, take the Aisin hub to a machine shop and have them match the base deminsions and bolt pattern, some longer studs and you are done.
Is it just me, or can nobody else picture those spacers fitting anywhere outside the hub that would allow them to stop the birf from moving inwards? Or is inwards actually outwards? Or is outside inside?
Bobby's hub gear, I thought all it did was allow IFS hubs to be used on SFA? Is anything different between the OEM hub gear and the BL hub gear other than the metal?
