Single Tail Light Not Working
England
Hi, I have a Land Cruiser Amazon 100 Series and the right hand tail light is not illuminating. When checking for power, there is none to the ligth housing or the white multiplug behind the rear light cluster. Does anyone know off-hand the main multiplug locations so I can check for continuity?
Many thanks!
Many thanks!
Hate to say but there may possibly be a break somewhere in the harness which is why you must be asking to look for continuity. These trucks have a lot of rub areas. I’ve had very similar issues in the past especially in the door harnesses. Good luck
did you track down the issue? I have the exact same issue and I know this is something recent. Right side brake light and reverse light do not work, no continuity at the sockets. Driver side (Left) does work. I was thinking a wire? but it seems odd both my brake light and reverse light are out only on one side.
