Single Stage and Base/Clear on same vehicle
Central Iowa
Hello everyone,
The shop who is working on my 77 fj40 is suggesting I do a base/clear out the outside but single stage on interior. Has anyone done this or heard of doing it? Thoughts/concerns?
Also, even though the look will be different from original I am thinking about doing base/clear on the outside thinking it may be more durable or hold up better than a single stage paint. Is that accurate? Or does the base clear really only get you a more vibrant/shiny finish?
Thanks so much!
Also, the shop is planning to use axalta paints which I understand is what the Dupont paints are now called. The single stage paint is Nason Ful-thane. Cant remember what line he suggested for base/clear.
I used the nason ful-thane on my build and it turned out great, just be aware this is their economy / intro line. Nothing wrong with that, as long as your guy isn't charging you for a premium paint.
Assume you are going with a non metallic color? Most shops won't shoot metallic in a single stage.
Jon,
Awesome info, thanks. I'm a bit disappointed to hear that it's the low end paint. They haven't sold it as great paint but said it was good. They are suggesting the ful-thane on the outside with clear. Just ful-thane on the inside with no clear.
What would ful-thane cost a gallon? What would the axalta better paint be called and cost? Im6having a hard time figuring it out online.
Thanks so much!
I purchased a gallon of ful thane in Audi Nardo Grey and it was around 275 ish including reducer and activator. It's not cheap paint but it is axalta's intro line.
