Single Speed Conversions?
I'm thinking of converting my old peugeot to single speed. I have angled drop outs in the rear, and I've seen other bikes with similiar drop outs go without a tensioner. My question is, what do I do with the rear hub? I've seen some single speed hubs for sale, but I'd prefer to keep my freewheel hub; if that is what it's called. I've seen spacer kits, could I just replace all my gears but the one of choice with spacers?
I assume by single speed - you meant a single freewheel as supposed to fixed gear or existing 5 speed freewheel. To convert to fixed gear you will have no choice by replace the rear hub. Of course, you can also keep the existing 5-speed freewheel, and use only one of sprockets - it wouldn't be too hard to find the right one to align the crank chain ring. But I personally hate the look and do not recommend it.
Assuming you are planning to use a one speed freewheel, there are a couple of options. The easiest which is what I usually do is to replace the drive train as well as the wheel set. (I usually do both wheels but it is the rear that matters). This is not the cheapest way, but it is hassle free, you got to choose a crank/bottom bracket that is made for single speed, and possibly a flip flop of fixed/single rear wheel, plus you also get to choose the bolt down hub than the quick release!
If the budget is limited, you might have to choose what to keep. Technically, you can opt to keep both hub and crank. But it gets pretty tricky to align the drive train. The key for the single speed bike is to keep the drive train perfect straight. (Yes I meant perfect straight). It looks like you got a pretty good crank, I'd try to keep that. You might have a better luck if you know someone that has access to different length bottom brackets. It is not too hard to find different length of the old square bottom brackets.
Finally, if you really have to use the same rear wheel (it would be the last thing I'd consider to keep), it would be a lot of work. You will need to find the right "center" by adjusting the spacers and the crank, then "re-center" the rim... I have seen people doing it, but I am too lazy to even give a try. :rolleyes:
Good luck and keep us posted.
I can't tell by looking at your pictures whether you have a Free hub/cassette or an older freewheel set up on the rear. If the newer, free hub set up, then you might be able to remove the cassette and replace it with one cog and a bunch of spacers. If you have the older freewheel hub, then you can get a BMX free wheel cog and it should thread right on.
This is a pretty good article on doing this conversion: Singlespeed Bicycle Conversions by Sheldon Brown
Depending where you will be riding you might want to also change out the front chain ring to match it with the rear gear you are using to get your correct gear ratio. One thing to avoid is to have the rear cog tooth count divide evenly into the front cog tooth count. For example a 16 rear, 48 front would be bad. doing this will cause faster chain wear.
2mbb, how do I tell which hub type I have? I take it in an old freewheel hub the gears all thread on, whereas only the smallest gear threads on a cassette?
If I was to get a new wheel/hub setup, would this combo work?
rim
Amazon.com: Alex RP15F Rim 700C 36H Silver: Sports & Outdoors@@AMEPARAM@@http://ecx.images-amazon.com/images/I/31lAHBXY8fL.@@AMEPARAM@@31lAHBXY8fL
hub
http://www.bikepartsusa.com/cgi-bin/category.cgi?item=01-113729
or
http://www.bikepartsusa.com/bikepar...-36HOLE-BLACK-REAR-HUB&category=hub-rear_hubs
the older freewheel set up has the freewheel functionality built into the assembly with the cogs and it should unscrew as a unit. with the free hub the freewheel functionality is bolted to hub and the cogs can be removed and replaced as a cassette. Both require a special, but different tool to remove it. It might be easiest to bring the wheel to your local bike shop and ask them which tool to use to remove it, then you will know what you have. or take your wheel off and take an in-focus picture of the cogset.
Here's more info back at sheldon brown's website: Freewheel or Cassette?
Regarding the parts, I personally wouldn't feel comfortable riding around on a $5 hub.
You should check to see what size rims your old bike has. I'm not sure about peugeot, but a lot of bikes in the US sold in 80's and earlier had 27" rims, which are different diameter than 700C (the new rim you identified). It starts to matter when your brakes don't reach far enough (700C are small diameter than 27"). Some brakes have enough adjustment, some don't. You used to be able to purchase a drop hanger for the brake, but I'm not sure they are available any more. You might have to purchase a different brake (longer reach) or try and find a 700C rim. If your existing rim is good you can reuse that and put a new hub on it, but you haven't said how you are going to get the wheel built.
