Single cracking noise-
I did a search to see if anything like this has been discussed but I could not find anything. I have a single tick sound that I get about 1-3 times during the first 10 minutes or so of running the truck (after it has been sitting for a while so it is cool). The sound to me is just like what you would hear when you turn the truck off and the exhause gives a single cracking sound as it cools down (coming from the exhaust I assume). This sound seems odd to me to be hearing it while the engine is running. Would this be a Cat problem or something with the exhaust? The noise seems to be new (past month or so) so I thought I would ask.
Thanks
Andrew
Sounds very, very serious. Can you get a recording and post a link to the WAV file?
-B-
I know your advice Beowulf sell the truck for $5,000 or less ASAP. Thanks for the help as always :) .
I think you are correct whodat as far as the sound. I am not sure what the life span is of the CAT on these things. Time will tell. It is become more frequent so I will see how it goes.
Thanks
Andrew
>> I know your advice Beowulf ...
Darn, you're on to me. Was it the second "very" that tipped you off? :D
-B-
I havn't noticed it on my 80, but on my previous vehicle (96 S-10 PU) I would get a loud cracking noise EVERY time within the first few minutes of driving. No matter what season. Mine sounded like it came from the under the dash area...and a couple times it was so loud I would look to make sure my windshield didn't just shatter. I never thought much about it though...just assumed it was something with heating up/plastics...something of that nature.
I will listen closer this morning with the 80...
Tick inside valve cover
I just noticed a metal on metal 'click' noise within the valve cover on the 1997 80 series. It sounds like a spring snapping, almost like a electrical spark, but more mechanical. :frown:
These are the facts:
I noticed it after I drained the radiator, filled with tap water, ran the engine for 4 min, and shut off. I figured it was water evaporating from the heat shield. Today I changed the radiator, fan clutch (old one WAS toast), water pump, thermo, and hoses. The truck starts normal and drives normal.
The ticking occurs every 20-30 sec when the vehicle is running. It is independent of the RPMs. When the vehicle is shut off it starts to slow down in rate (most likely directly proportional to the cooling rate???)
We were able to pinpoint it to inside the valve cover. When the PCV valve is pulled out, the noise level increases.
What could possibly make such a loud noise when nothing should be moving under the valve cover?
