Single Barrel Leak- SD40. '67
Bainbridge Island, Washington
So I've read about the leaks others have with old carbs, and to expect some leakage, but it seems to drain out even faster than it did when I first got the rig back together a year ago after a complete rebuild, including the carb. The bowl is drained in less than 8 hours or so (used to be almost 24 hours). Pulled it off, cleaned the exterior and waited for the leak to appear. I believe I found the spot (though I could be wrong)... the little domed plug that I'm shining the light on in the picture. I suppose it's a plug to fill in where a passage was machined; any suggestion on stemming the flow?
And then again, what about replacement alternatives?
With short trips, and the bowl constantly draining, I'm getting about 10mpg... which goes way up to 12 on a long trip!
