Simple SOA
isn't there some place in salt lake city that does the cut and turn for you for a good price?
come to think of it, i remember someone saying that they/he/it/them will do the perches, and a number of other things. seemed like it was a good price to me.
maybe i'll search for that thread.
[quote author=rusmannx link=board=12;threadid=16186;start=msg155893#msg155893 date=1084421459]
[/quote]
www.Proffittscruisers.com sells cut and turned housings complete with perches, shock mounts and steering stops for $350.
With a spring over (7 inches of lift) and 1.5 from the springs you will get binding when crawling, I wasn't talking about highway driving. The only time my rig sees a highway is from its trailer.
I'm just happy cause now my pumpkin can't dent my erl pan anymore.(i'll have to get some picks of the small dent in it)
slower how did you get 7 inches out of a SO? then you went another 1.5" in a lift spring? you run 46 or 49" tires? did you pull measurements after she broke in.
front u joint bind also matters on the length of the driveshaft, and too many setups to generalize a statement.
cut and turn not needed, with a SR then is strongly recommended but so is wheels on the mounts as your diggin them in.
cali hydra boost? or go manual.
rotate front 2 degress and add longer shackles? what do you have for a caster angle? sounds like you lost it or gone too far.
i thought that 6-8" was standard fair for an SOA.
also, pretty sure that 35-37" tires are what most run with a stockleaf SOA.
malphrus
[quote author=72cruiser link=board=12;threadid=16186;start=msg156346#msg156346 date=1084475034]
malphrus
[/quote]
38's fit easily on an old flat ass stock leaf SOA.
I measured my front framehorn once on my cruiser (SO and 38.5 sx's at 20 psi) and compared it to my near stocker (2.5" longer shackle and 31's) I was only 8" higher with the 78 than the 72. Of that, at least 4" was in tire alone..
maybe the 6-8" was with tires, i guess
5 to 6 inches on a SOA setup with stock springs...but it also matters how ya do it with the stock springs...i did an add a leaf and 2inch shackels and got a hair under 7inchs when i was done.. but im down to about a 6inch lift after the springs have settled or flattened out..and thats with out tires...by da way :)
I agree ..can't see how you could possibly retain positive caster by doing this. Have you measured the caster?
[quote author=HI^C link=board=12;threadid=16186;start=msg156330#msg156330 date=1084474514]
[/quote]
Uhhhh, ok, I never said that but whatever.
[quote author=cali-cruiser link=board=12;threadid=16186;start=msg157295#msg157295 date=1084571518]
I haven't measured caster(where should I measure from) but it is't postive.
[/quote]
From the top of the knuckle with the vehicle at rest.
Factory is +1 I believe, correct me if I am wrong.
the next section i miss read what you said, you travel 1.5" then have ujoint bind.
did the 7" SO settle out?
+1 degree caster
I set mine by pinion angle, meaning stock pinion angle without cut and turn gives you stock caster angle when SO.
I believe stock pinion is 2 degrees (been a while, dont use it till degree is confirmed) dont have the tools to measure proper caster at the knuckle, and with 1 degree it is too hard to guessimate,(no setting angle finder across the bolts). SO if you put on about a 2" longer shackle then stock you tip mounting surface of the perch approx 2 degrees (math invovled), but if you welded perches to compensate for the extended shackles your ok.
its the rotating 2 degrees then the mention of longer shackles also that has me wondering what you have for caster.
nice sig line(hic)...my front caster is stock but i rotated my rear up 2 degrees to get rid of a vibration i had....so no its not stock in the back but either is having a soa set up.. having it roated up 2 degrees to get rid of a vibration is prob. a good thing..
