I just finished doing this on my '92. The easiest way is to remove the plastic mirror "housing" from the rest of the assembly (motor, etc.). Once you have nothing more than the plastic housing that the mirror sits in (and the pivot axis on the backside of that piece) then you can start. I cleaned my mirror housing with some wax and grease remover then peeled off the sticky backing on the pad of the new mirror. Then, starting with the largest side of the mirror (the side that sits closest to the vehicle) slip the new mirror into the housing. Using your thumbs, move carefully around the entire mirror, gently pushing the mirror down while pressing the plastic back a little so that the plastic housing slips over the top of the mirror. It's a little nerve wracking but just take your time and don't apply too much pressure. I didn't use a heat gun or any lube on mine but I can see how some soap or vaseline or a heat gun could make the job a little easier. Good luck! Let me know if you need clarification on anything.
