Well it finally happened. I had been planning to attack my driver side mirror to stop its inssesant shaking and I was actually planning on doing it today since temp is in the 70s. Then it broke. It was flapping back and forth as I ran to the grocery to buy some eggs and tabasco sauce.
I rigged it quite well. I think it will be fine for a long time to come. I will post some pics and describe what I did to "fix" it.
First is disassembly. It was very easy for me since the spring retainer popped completely off. However, if someone is going to dive in before their mirror is completely broke they will have to remove 6 screws before they will have access to the frame and spring assembly.
There is one screw under the mirror into the carrier, one at the end of the mirror housing, and four on the inside that hold the frame to the two housing shells. After all of these are removed you are left with the frame held on to the ear sail by the spring assembly. Mine was easy since it was broken but I imagine that 2 clamps are as critical when removing the mirror as they were for me when replacing it.
Watch for the 3 ball bearings that are under the frame pivot.
