Side mirror electrical plug how do you disconnect
Bought a set of aftermarket replacement side view mirrors. Took off the triangle black plastic cap inside and have removed the 3 bolts. Looks like the wiring goes deep inside the door to unplug the connector. Any simple way to do this without removing the entire door panel. I read a thread on this which mentioned just removing the speaker as the plug is located behind the speaker? Would this entail removing the door panel or can one just remove the speaker?
And in another thread it mentions that the plug is located in the mirror rotational housing?
Any how to's or help would be great. I'm tired of this broken mirror.
They should snake in and out with a little patience.
I just did the swap 2 days ago. You pretty much have to remove the door panel. The harness is taped to a plastic clip just above the connector that you will have to remove, then reattach the new harness to in order to keep it from flopping around, and possibly interfering with the window.
Yup that's what I thought. I'll need to remove the door panel, then the speaker and disconnect the harness plug. Was hoping that there was a simple way to do it but I guess not.
