Anyone ever have their speedometer gear on the t-case get shredded? My speedo was working fine for about 200 miles after my t-case rebuild. Then one day it would fall to zero, then come back, then fall, etc. Then it stopped working entirely. So I figured I needed a new cable. I put the new cable on, no dice. Spun the old one, it worked fine. Then when I was re-shimming the rear bearing on the t-case (I had the preload wrong, had a little play at the back) I found the plastic gear shredded. I think this has a lot to do with the rear bearing preload being wrong, but I've had slop at the back of the case for at least 10k miles. When I disassembled the case the plastic gear looked perfect. The only thing I could think of was maybe the drive sleeve was on backwards? So I spun it around, just in case the thing might be directional in some way. Anyone else have any thoughts.
