Should I run this input gear?
RWBeringer4x4
Mechanically Challenged
The People's Republik of Maryland
Hey all,
I’m getting ready to put my transfercase back together but found two very small edge chips in the input gear. I’m not a transmission/transfer case guru so I wanted to bounce it off the collective and get your opinions. Is this safe to run?
If it is - is there anything that should be done to prevent the small chips from becoming big chips?
This is the larger of the two:
And the smaller -
I'd have no issue running that gear, those chips/imperfections are very small. Just make sure the surface is smooth, maybe rub it with a bit of emery cloth and go.
Awesome. I assume all these likes are in agreement - in which case I’ll run it. I figured it was probably alright but as all of this is uncharted territory I figured I’d check.
