Gents,
Hoping someone can help out there.
Simple PM job... changing the belts... Except someone siezed/stripped up the set screw on the alternator adjustment! Ended up having to cut the old belts and remove the alternator, so I could drill out the set screw. In my frustration, as I hesitantly began to remove the Alternator... Yep, I forgot to disconnect the batt. Arc'd the alternator nut to the intake manifold w/ the socket wrench. Smoked the positive terminal...
Got it all put back together, but no start. No spark to the ignition coil.
Turns over, get gassy smell from the tail pipe while cranking, just no spark.
Checked the EFI relay (Not smoked and checked a new one)
Checked the fusible links, (not a master w/ the multimeter, but appear good. Appears to conduct well).
Ignition coil looks/tests good.
Of course, checked the usual suspect fuses and they all appear good.
This has to be something small that I'm missing. Anybody got any suggestions out there?
Thanks,
STL Doug
Thanks,
STL Doug
