Short on A/C
Are you sure it's a short and not a leak in the A/C system? I leak will cause the low pressure sensor to deactivate the compressor.
When I switch the A/C on the fuse blows. I've plugged out everything that I can (compressor, pressure switch, relays and plugs on the loom) and probleme still there. There is one wire that has earth that I think is the probleme but I need to know were it runs, busy stripping the hole dash but I am getting no where,to many wires:mad:
