Here's the issue.
Belts are about 18 months old.
Just replaced water pump so tension should be good on the belts.
Battery was replaced about 2 years ago.
Fusable links are 2 years old.
Negative battery cable is 2 years old.
- Headlights off everything is fine, truck is charging per spec.
- All accessories including 1000w amp on, headlights off, truck charging fine.
- headlights on, accessories off, needle drops to about 12v at idle 600rpm. Doesn't drop any further.
- headlights on, accessories off is the same as above.
- headlights off or on and using the directional signal and the needle drops at every blink then returns.
- headlights on and raise rpm to 650 and everything is fine.
- No issues starting.
truck is very similar. I put a stock sized battery in her rig (cheap, needed a replacement quick type deal) and I believe that the smallish battery is the cause of what you're seeing.
