short box on 40?
has anyone customed a 40 with a 45 short box?, i heard some of the old 45s used the same frame , wheel base as the 40's. is is as easy as putting the 45 cab and box on 40 frame? i think it was aqualu that sold the short box for "fj45 or custom fj40." i'd love to see pics if anyones done it.
Cool Cruisers built a "45" out of a 40 and a mini truck bed, probably still on their website somewhere.
here
coolfj40_1932_209685319
I don't think that is correct. I believe that the FJ40 has a 90" wheelbase where the swb pickup has 95.7.
Nope. SWB pickups had a wheel base of 104" same as the FJ45LV. The FJ43 had a wheelbase of 97. You have to lengthen a 40 frame for the SWB bed to fit or find a LV frame like I did. Good luck.
I haven't seen this pic/rig before. Maybe I have been under a rock for a while or something. Strangely I like it. The only thing I would have done differently is to make the sheetmetal in front of the rear wheel more "flat" to match up to the cab better. For the non purist is that bed a viable option for a FUBAR FJ45 bed? Let's hear from the peanut gallery?
as oldIron said do a search its been talked about before and here are some pics you will find.
I am also currently converting a 40 series into a 45. It is definitely not a 'purist pursuit' and the decision was made due to the amount of rust in the rear tub. The frame will need to be lengthened at least 1 ft. To do it properly it must be lengthened in the middle of the frame (just after the tranny mount). This has been done and there is a writeup on here or on Pirate. My only suggestion is when you do the conversion, make the cab longer then a stock 45 if you happen to be any taller then 5' 10".
Curtis
