shocks
Its time to put new shocks in the 97' and I was wondering which were best to go with? I know this question usually causes alot of debate, but these shocks are not for off road, i'm thinking something like the stock shocks with a bit lower of a price since they are not from toyota. Anything that will keep the stock ride, not much softer, not much stiffer. Thanks
Just put a new set of stock yoda shocks on my '96.Lasted 186,000 and the price is competitive with aftermarket...the steering stabilizer(250.00 from dealer here),however is another story.....
I had my shocks and springs replaced two years ago with CDAN. The Toyota shocks are a bit stiff when it gets cold. I would rather have a slightly softer ride during the cold months. Aside from that, the vehicle never loses it’s grip on tight cornering.
Did you get the shocks from the dealer in town, also? If you don't mind, how much were they? I am thinking about buying some from Cdan, but wanted to check my options.
I recommend getting OEM shocks from Dan. Should be a little over $100 for all four corners. They even have rock guards welded on them for added protection. Can't go wrong with factory equipment if you don't plan lifting the rig.
How Much ??
:eek::eek::eek:
How much for that stabilizer??:eek::eek::eek:
Man-a-fre sells the OME stabilizer for $77
They sell OME shocks for the 80 in light and firm dampening choices, in extended lengths for lifts, and standard length for stock height.
While these are currently $86 each, they have a HUGE piston, rock guard, double tube construction, require no adapter hdwe, dampen extremely predictably (IMHO) and are holding up so well after 50K miles, I expect they could last the life of the vehicle.
While 90% of my driving is on road, and their performance is tops at 75mph, my "driveway" is 2 miles of winding 10% grade dirt road so, everyday I'm "offroad", and these shocks soak up the washboard with no fade. Check out the dual valving modes these have. They were designed for the "corrugated" roads of OZ.
I've run the KYB, Monroe, Koni, OEM, and I like these the best.:bounce::bounce:
Had Bilsteins on our '94 for bit over a year. Some stiffer than the OEMs, but in a pleasant way - Like 'em, will do the same again when its time down the road.
thanks for all the replies. I think I will just go OEM on the shocks. They aren't much more and lasted me 150,000 miles/12 years so I can't really go wrong with them.
