Shocks Not So Good...
Bend, Oregon
What do you guys think, do I need some new shocks? I did know that they were leaking, but this one appears to be completely gone. When I removed it to do the PHH/starter/flush I noticed the shock. The other 3 are not as bad.
I can not afford to get the OME 2.5" lift right now, so I plan to call cdan in the next couple of weeks to order OEM shocks.
Just thought I would share my findings.
Riley
P.S. Brake pads are down to about 60% after ~10,000 miles. Seems about average.
stk shocks are top notch.
Doug
I know this isn't tech, but upon reviewing your signature...I must agree owl sh&% on a wet log is slick, but I don't think it's as slick as greased whale sh&% on an iceberg..my .02
I have read recommendations from you and many others about going with the OEM shocks if not going with a lift. The ~$120 for 4 purchase price is really the biggest reason I am going that way. Some day I will go for a lift, I just have way too many other things I need to do (front & rear axle rebuild is #1) before spending money on fun stuff.
Thanks again for the recommendation!
Riley
I have a new front Bilstein I got stuck with if you want it it is yours for shipping from 85044.
I appreciate the offer. If I were going with Bilsteins, I would jump on it. The cheapest price I can find Bilsteins for is ~$60 per. Even if I get yours for free + shipping, I would be spending more money than the OEM.
I am sure someone will jump on it, I just need all 4 and want them to match.
Thanks,
Riley
Riley,
The rear shocks can be a pain. Slide under there with a bright light to see what you're up against and understand the following tip.
There's a metal plate that the rear shock bolts to and a captive (welded) nut the bolt screws into. Others have a heck of a time with this and if it breaks loose you're in a world of screwing around. Here's what I do - 3 successful shock changes so far.
Get some PB Blaster and also some of the red tubing that comes on the can to get into confined spaces. Most auto stores will sell it, but it may be smart to call around first so you're not wasting time. With a foot or so of the tubing on your can spray tip, you can use one hand to get the tip up atop that metal plate and pointed right at the bolt threads that are up there while the other is at the can spraying. Prepare to have the stuff come down on you, and spray the heck out of it to dislodge grundge as well.
Do this to all 4 bolts and the next day when you go out to loosen those upper shock bolts you'll have a happy day. If you can do it twice a few days apart you'll have even better luck. Of course, spray all the other bolts as well, but they're pretty straight forward.
Be sure to search for front shock loosening techniques as well since it may take a pipe wrench and other messing about to get the top ones loose.
DougM
Riley,
DougM
Doug, once again, above and beyond the call of duty!!!
I did find and purchase 3 cans of PB Blaster and have some various size clear tubing.
I will pull a rear tire and get a good look at everything.
Luckily, I have yet to run into any bolt or fastener on this vehicle that has not broken free with some mild pressure/force. The only fastener I have broken has been one of the wheel well flap holders (just this weekend).
I will start to re-read the threads about shock replacement (it has been a few months since searching for that particular item...).
Thanks again Doug!!!
Riley
Riely,
I am guessing from your pic that you bought her on the west coast?
I see minimal to no rust.
When I did mine I sprayed them 2-3 times the night before and all came off with ease:cheers:
Riely,
From the carfax report, it started in California, went to Florida, spent some time in Colorado, then migrated to central Oregon where it will stay for quite some time. 196,578 miles later, it is still a pretty happy girl. The head gasket is probably in the near future, but I will cross that bridge when I get to it...
Riley
Thanks,
Riley
No problem. I got stuck with it last year when shocks.com sent me three front & 1 rear. I did not look at them until a month+ later when I got back to Mexico & had them installed. I posted it here for sale & it has sat since. Your prediction has come true I have a pm asking for it & since you said no thanks I'll send it on to him.
Riley,
DougM
I just pulled mine Saturday. If you look closely you will see that you can spray the head of the frame side bolt from the wheel well. On one side you may need to hold a wire loom out of the way. On my truck the space between the frame and body was just wide enough to spray the hard to get bolt. The other, inside, bolt is a piece of cake from below the truck.
:cheers:
Thanks to all for the advice. I have been reading through the archives and Slee's install instructions (with pictures!!!) Everything seems pretty straight forward. It does not appear necessary to bust loose the sway bar or loosen the brake line brackets just to change the shocks.
I will try to snap photos of the procedure and mention any pitfalls I run into.
Thanks again,
Riley
