Shock travel
14's, front and rear...get the rig 'balanced/teetering' on the left front and right rear tires (opposites off the ground, barely) with no shocks installed...that's your max compression and extension. Take a set of 14's, mount to the axle side, and modify top mount points as needed.
Ford shock towers work great in front, add a few inches...there are also aftermarket taller towers out there that 'look' stock. I run a custom hoop for mine.
Rears are thru the bed to a custom mount. You may find 12's work in the rear better, tipped inwards a bit...don't tip TOO much tho, you lose damping quickly at steep angles.
The more vertical, the better damping you'll see.
