shock size for SOA cruiser
a 10 inch travel shock will usually suffice and if your mounts will permit you may be able to get 12 " travel ones on there. bilstein 5125 series 12 " travel are nice for the price. 80 ea IIRC.
10 inches of travel is too short for every SOA I have ever built. Get 14 inchers for the front at least. It's easy to use every bit of that. You can get away with 12 inchers in the rear.
Don't buy your shock to fit your shock tower or mounts. Install your tower and mounts to suit your shock. Pick your shock to suit your suspension.
Mark...
10"ers are all I could fit in the back of my cruiser without limiting uptravel, without going thru the floor and without going to a stupid angle, I would rather have the shock dampen properly and limit a little flex. It still gives enough travel to drop a 37 below the rocker
