I just installed a set RS9000s on my 70 with a a spring over conversion. With the vehicle sitting level, the front has 4" of shaft showing and rear has 3" of shaft showing. Does anyone know if this is about the correct length? I dont think I would bottom the shock out with 3" of upward travel available. I set the shocks at a 1 setting (softest) and pounced on the rear and could only get 1" of movement out of the shock. It looks like this is a 30/70 ratio of upward to downward travel available.
If they are not the correct length I want to send them back before I run them on the trail.
Thanks --- Fman
Thanks --- Fman
