Shock absorber replacement
Utah
One of my rear shocks is leaking. It's been quite a while since they were replaced, and I believe they are aftermarket... I don't want to do just one, so I'll be getting a complete set of shocks.
I don't have plans for a lift anytime soon, but I've *heard* that the OEM shocks are a little on the soft side... I like a stiffer ride, any recommendations for that? or will OEM be the best bang for my buck?
My question: I've never replaced these things before, how difficult is it? I assume the mounting hardware will need liberal amounts of PB blaster...
Thanks
-Lane
EDIT: I have searched.:flipoff2:
Pretty easy, a :banana: job if you don't mind crawling around underneath and you have some basic tools and jack stands. Go OEM if you're NEVER going to lift, put on adequate aftermarket (OME or Bilsteins) if you're considering lifting anytime.
I know for a fact that a lift is one of the last things on my mind. I rode on 35's a few weeks ago, with minimal rubbing :D
OEM it is. Thanks :cheers:
Dunno if you found my post on shock replacement in your search, but PB with a plastic tube allows you to get the stuff atop the rear shock upper mount where a bolt that commonly breaks resides. Crawl under a week in advance, then a couple days in advance. Use your fingers to position the tube directly against the threads you can't see and soak 'em.
DougM
Thanks
-Lane
You can pick up a new Old Man Emu suspension kit with a 3" lift from man-a-fre for $750 on sale right now (or at least it was on sale last week). I dont know how much OME is but $750 is cheep and is better than stock. Also, Old Man Emu is a direct replacment so there is no cutting or modifications needed. Cheers.
That would be nice....but I don't have $750. :frown:
THAT is what charge cards are for! :D
BTW - I have a 69 VW convertable starting restoration - good luck on your 63!
