Shifter slop question
Destin, Fl
74 fj40 - f engine - stock 4 speed.
Anything to help eliminate shifer slop? I replaced the transmission, for diferent reasons. This 4 speed is better, but still alot of slot, really don't feel the "H" pattern. When I had the shifter out there does not seem to be much that would help. Any ideas, I know this has to happen to alot of people, I've had 2 trans with the same thing. Checked SOR's pics and that is pretty much what I have.
Number 4 on the pic is all I see that may help, but not much. See attached pic.
Thanks guys.
Could be the pivot pins #99 are worn or loose, replace them and it's tight again, I usually tap the holes cut the head off a bolt the screw it in and have a permenant tight fix.
blueflame-
How long have you owned this Land Crusier?
How many other Land Cruisers have you operated?
Before you operated Land Cruisers, what were you driving that had a manual transmission?
Thanks!
-Steve
I've had it about a year, no other Land Cruisers in the past. I have had many manual shift, drive a 6speed viper pickup as my other driver and the shift is very tight. I really don't have a problem with it, it just should be better to not have to fish around for the gear. And everything I had before had some kind of reverse lockout. If this is just Cruiser character then I'm ok with it, just seems there would be a simple fix, has been on other vehicles.
Maybe just getting more time in it?
All of mine have fairly long throws in comparison with newer transmissions but the cruiser is a truck as far as comparisons go, and an old one. I get nice positive 'click' engagements with the trans, (not so with the transfercase until I did a double stick on one - that's a world of difference and another subject entirely, sorry).
Reverse is pretty far away and I don't miss a lockout because of that.
Try not forcing or trying to shift fast. Let it drop into nuetral and then go to your gear in a relaxed sort of way. Speed shifts are for hotrods.
Check the pivots, and make sure the spring isn't broken. I did have to make new pivots for a 3 speed I have still.
Alright so live with it and drive it like the tractor it is. Thanks for the responses. This 2nd trans is much better than the first so I am actually pretty happy, just thought there may be more I could do to improve it.
More time driving it will lead to less 'fishing', and become second nature...
You are correct in the tractor statement, these are old work horse vehicles, with designs 50+ years old...
:beer:
If Hurst made a shifter for the 40 I would buy it tomorrow!
Long live my limp noodle of a shifter.
Welcome to cruisers man... what is a Viper pickup? Sounds cool.
Rezarf <><
Rezarf <><
Dodge SRT10 pickup, has the Dodge V10 viper engine. Very cool, actually gets worse gas mileage than the 40!!
