shift lever issue or???
Seattle, Wa USA
Hello. My 1994 transmission lever will only "lock" into park. In every other setting, I can simply bump it down towards the next spot. How much trouble shooting am I in for? Is there a little detent pin in there?
Sorry, I just picked up the fsm and see that there are potentially 4 points of failure.
for item 2c (page AT-76), apply battery voltage; I have a little bech test power supply, it is only 2amp though, will that be adequate? I don't really feel like fabbing up some sort of sketchy jumper wires. Or am I reading that step too literally?
any pointers are greatly appreciated.
-MIke.
The position "lock" feature is all located underneath the shifter console. Should be a :banana: to take the console cover off and investigate. Once shifted into reverse by pressing the brake pedal you should be able move the shifter to N and then to D without any shift lock. Shift lock is required to then move to 2 and 1. At that point moving the shifter back to 2, D and N requires no shift lock. Switching to R and P requires the pressing the shift lock. If that is not what you observe take the center console off by removing 4 screws on the side and also screwing the H/L shift knob. From the drivers side of the shifter you will see the notched positions for all the details. It is completely manual with the exception of the electric latch that requires the brake pedal to be pressed before shifting out of park. When the brake light fuse blows the electric latch is disabled. If that happened the PO must have forced it and broke the shift lock.
You can override the electric latch with your finger or screwdriver, no battery needed.
ppc; Thank you. I will investigate further today. My center console is still off anyway (was waiting until I was done running wires around before re-install) I guess I had thought that one needed to depress the lock/unlock button to make all changes.
