sheet alunimun??'s
in the garage
i have two 4x8 sheets of 1/8 or 3/16 aluminum.
i'm pondering tubing out the back of my 40 and re-skinning with the alum.
is it true that just a bit of heat will let the alum. bend with ease?
i'm thinking of the back corners here.
or i'm wasting time thinking about it :D
AL bends easily without heat..
Much easier than steel..
Use your torch and get a real sooty flame. Heat the aluminum a little, not a lot. It will soften it so you can bend it and work it. It will loose it's memory after you do this.
Jessie James had a really nice demonstration on this duirng his Discovery chanel series West Cost Choppers. He was making fuel tanks for his motocycles.
THAT'S WHERE I SAW THAT!
will it stay flexable till mounted?
is the aluminum 5052 , if so it will bend without heating......
if you do heat, quench it with water and it wont tear along the grain stucture......
i am building my own tub and i am almost at this point to bend the rear corner panels... just trying to find the time.... i have a build thread in the 40 section of the floor... if you want to have a look...
cheers adam.....
