shear pin location
The shear pin for the PTO winch is located in the winch input shaft, going through the winch input shaft and the u-joint in the PTO shaft. It's retained by two cotter pins on either side of the shear pin. It's a HUGE pain to change in the field, especially when you're in the process of extracting yourself from a sloppy northern MN trail . . .
Figure 72, parts F & G here:
Shear Pins @ SOR
Someone here probably has the OEM part number for the shear pins.
