A few different things on the table here....(I am SOA)
First, I have seen this design locally (I am sure it's popular) where the front perches (fj40) are reversed, moving the "eye" back about 3-4 inches. You then in turn get a 7" shackle (bear with me) and use it.
What does this do?
1. They are slanted, and the ride height is the same. So the caster angle does not change. Everything else is unchanged. Just picture if you will a long shackle slanted up towards the cab.
2. The effects of this are MASSIVE droop. I mean, huge droop. Plus, the spring can actually invert becuase of the ability go up so far now. Drive quality is NOT hindered, nothing is changed.
3. The adverse effects are the wear and tear on the springs, becuase the articulation is incredible.
Next.....
I am not only going to do this, but also am considering revolver shackles in the rear. Why? Well, you get the same effect as the above, but to a lesser degree, and you don't have to move the perches/weld anything. My only worry here is that this will provide lift in the rear causing the rear to ride higher than the front.
Thoughts? Ideas? Suggestions?
Thank you.
Ragman
What does this do?
Next.....
Thank you.
Ragman
