shackle slop.
I've been tracking down the vagueness in my front end for a couple of months... steering is all within tolerances, yet it still wanders all over the road.
I've been told that it may be due to slop in my shackles etc... my shackle rubbers are fine, but i keep chewing out spring bushings in the solid mount at the back of the axle... it apear that the axle is moving side to side (across the chassis) using the rear mount as a pivot...
what can be done about this?
shackle length is stock.
have you done an alignment? If you did the big tire alignment (Tape measure across the front and back of the tires) then turn the toes out a bit and see if it improves.
haven't done that...
i've been driving this rig for 3 years and it only started doing it recently...
tie rod ends and steering linkages are reasonable... as reasonable as before the problems arose...
pretty much feels fixed...
who'd have thought 2 degrees of castor makes that much differencea
