A half inch increase on the front axle is insignificant.
By "doubling" in back, I don't know what your original size is, so it could be a 2-1/2" over stock shackle, or a 3" over stock shackle.
But either way, with stock springs, you're only lifting a maximum of 1.5" at the axle.
That's pretty insignificant as far as pinion angle is concerned. UNLESS the springs happen to be lift springs. If the springs are stock, then no worries. It's also possible that the springs could be fatigued, and the shackles were installed simply to make it ride level. You may need to park on a level surface and see how level your cruiser is.
