Shackle bushing question
Torrington, CT
Well I ordered all new greaseable shackles for my 71 40. When I bought this truck a few months ago it came with a complete bushing set. My problem/question is the bushings are a tad loose. Then can easily spin on the shackles and I figured they would have to be tight. Will these work or do I have to get different bushings? If I have to buy new ones where do I get them and how do I know they will be the right ones?
Thanks
Andy
Bushings have to match the spring eye inside diameter, and the shackle pin diameter. Otherwise, the steering will be sloppy, or the axle will shift around with unpredictable results.
I am not arguing with this at all - but having said that - I bought the correct urethane bushings for mine from SOR and I'm pretty sure I remember correctly is saying they are a "loose fit" on their outside diameters (into spring-eyes etc) and a sliding fit on their inside diameters (shackle pins). But when everything is bolted together - It is all pretty "firm/tight".
(I'm CERTAIN they were a "loose fit" on one side or the other.)
I think if everything is too tight you inhibit "suspension flex" too much. (The spring eyes must be able to twist relative to the shackle pins etc.)
(And I doubt whether many forties steer or handle - on road - better than mine does. :D:D:D)
:cheers:
PS. Just double-checked with bushes and pins that I have here that are yet-to-be-fitted to my rear suspension. They are a "tight sliding fit" on the pins ("easy sliding fit" if I were to add grease). This means they will indeed be a "loose fit" in the spring eyes. And I'd probably go as far as to say - a "very loose fit" there.
Oh and I took some measurements.
Bushing I.D. - .610"
Shackle pin O.D. - .585"
so a difference of .025"
Ok right?
Hmmm.:hhmm:
Right - Got a brand new fixed pin in my hand now with an "imperial" vernier micrometer. Let's see........... Its OD measures 0.586" (Should be 15mm) That's close-enough to your measurement.
Now - got a brand-new SOR-supplied urethane bush in my hand with what looks like "Specter289-40-S" moulded into one end. - Its ID measures 0.575" (14.8mm) with vernier callipers. :hhmm::hhmm::hhmm:
Try again - Same result!!!!!!!!!!!!
So I'd say No!!!! Don't fit them.
It looks like the bush ID should be slightly smaller than the pin OD (meaning that the bush OD increases slightly when the bushes are pushed onto the pins - or when the pins are pushed through the bushes).
:cheers:
...It looks like the bush ID should be slightly smaller than the pin OD (meaning that the bush OD increases slightly when the bushes are pushed onto the pins - or when the pins are pushed through the bushes).
this has been my experience as well.
Installing a Hellcreek lift....
x3....I'm installing a lift right now and your ID on your bushings don't seem right. My bushing diameter is just a bit smaller than the shackle hole diameter.
Well thats proof positive. thanks guys. Im off to order the right ones. Anyone need some oversized bushings?
Yes. I'd say those bushes were meant for either 5/8" pins or 16mm pins.
:cheers:
