SF converted to FF...
Carthage, MO
Before I go hacking up an axle housing, I would like to ask if this could be done? Take a front disc axle's spindles, bearings, discs, hubs, and axle shafts and combine it with a SF housing. Cut the SF housing just past the bearing, measure so a regular FF shaft could work or use the front shafts with a lockout hub, make a plate from the front knuckle housing to hold the spindle, etc. Custom axle shafts could be made as well. What do you think? Ideas? I'm guessing this has been done, but not documented? Thanks!
You'll end up with an axle that has a narrower WMS measurement if you lop the SF ends off and weld on the splindles. Start with an FJ60 rear and go from there for a 40 series.
