Setting in a sm420/3speed
Carthage, MO
Question, when placing a sm420/3 speed in, do they tilt back somewhat when in place or can the output on the t-case be set at 0 degrees? I need to weld in the rear t-case mounts and would like to set this up right the first time. I am sua now but will be doing a soa in the spring. I want to eliminate any potential vibration! Thanks!
Engine transmission and t-case are all in the same axial line, there are no angled couplings. By logic the engine is in line with the frame, so the front and rear output should be parallel with the frame. All the 420 mount dose is rotate the t case down, this doesn’t nothing to alignment for and aft.
??? what the hell are talking about??? i think you just re-defined the whole topic of this thread.
I think you are all nuts (except nutley). Remove the bellhousing mounts if you are stock. Them darn things are aways keeping the engine level. Get a floor jack under the front pulley and crank it up as high as possible. Go just until the fan blades cut into the radiator. It will run hot after it self clearances but oh well. The output will point down now. Oh and throw away the front driveshaft.....2wd is much cooler. :flipoff2:
DIESEL40 said:
Another ?, if the rear output points down. Does this mean the front output shaft points up?
Yep, but you don't use it at high speed so the "misalignment" doesn't cause problems. Modern rigs must use a level drivetrain so they don't get front vibrations??
If your using a plate adapter between the 420 and the t-case it rotates the t-case downward by over an inch. So you will be losing a lot of clearance if you also tilt the rear output down. Maybe not a big deal after SOA, but crappy breakover angle until then.
