Setting AHC Height
nj
So I’m trying to dial in the ahc height and get pressures correct. The front was easy as I had a lot of adjustment in the torsion bars and it was sitting level. Pressure in front was high and now is sitting at 6.2mpa. The rear was high and with the addition of 30mm spacers on the stock springs I’m down to 6.5 with an everyday load. The problem is the front height (fender to center of hub is 19 1/2” on each side) is about the same as the rear( also about 19 1/2”) measured the same way. How should I go about adjusting this to get the 3/4” rake I need. The rear should be around 20 1/4” if I’m right. Should I just try to adjust the rear sensor, or lower the front sensor to raise the rear? Little confused about the best way to go about this.
You have to adj. the rear sensor to get the back end up. But this will increase the rear preasure too. You may need stifer AHC capatible springs like the Kings KTR's
