Sequoia Pro Coils
Your Mom's house
Has anyone with a new pro sequoia swapped out the coils on the stock suspension? Looking to add bumper and sliders and I’m worried about adding the extra weight. I’ve also got the Westcott lift with 35s. If so, how did it turn out?
I did the Eibach's on my Tundra Pro to fit in 37's .... very impressed with them so far... I added a .6mm spacer for the rear to level given my Decked setup is loaded typically and I run a bedrack....
It really smoothed it out nicely - and it's very planted at speed.... the rear when fully loaded with stuff 300lbs of stuff in the decked set up - plus weight or decked and bedrack) could use a bit more spring rate but it's still nicely composed... I di add the Dobinson .6mm spacer to level it knowing it would sit a bit down in the rear as I went with the 2.5" front springs...
