Seperating rotor from hub
The rotors off of my 78 front axle couldn't be turned, so they had to be replaced. I ordered new rotors from Advance Auto parts for $55 each and got them in the other day.
My question is how do I seperate the wheel stud/ bearing housing assembly (hub housing) from the actual rotor disc? I removed the 6 bolts from the inside of the rotor assembly, but it won't come apart. Is the housing for the inner wheel bearing pressed on? If so/not, how do I go about removing it? I belive the same procedure would be used to change out the wheel studs. Thanks.
