theo said:Seems like the fuel is a male spade too. If yours are broken off maybe you can solder or braze a connector back on? Or even a short piece of wire that you can then attach a connector to.
johnnyb_s said:You know, they are probably broken off, because I don't have a male or female end on there, just an empty post with a flat top. I think I'm just going to solder a piece of wire and crimp a connector on the end of it. Thanks for the help!
nuclearlemon said:female flat connector on the wire slides sideways onto the round flat top of the sender.
theo said:You should be able to buy socket type connectors to fit it, assuming someone cut your original ones off.
