Ok so I just replaced my rear pan hard bar/trac bar whatever you want to call it with an adjustable one. Well that's all good but the main reason for doing it was the clunking noise that came from the rear when driving off road or even when I went over a speed bump at an angle. Prior to this I thought it actually was the axles moving in and out of the housing noise I have heard while the truck was off the ground.
My truck is a 91 with the semi float rear (c-clips). For instance, I jack the rear tires off the ground, I can grab the tire and pull/ push it in and out of the housing almost an 1/8 inch and the noise of it hitting back and forth is the same noise I hear off road or hitting speed bumps.
When I did my gears and installed the aussie a couple years ago everything was in spec and has been working great since. Anyone ever have a similar issue?
Thanks
Thanks
