74' FJ40 that he had invested countless hours of work and cash in the process of restoring this truck, the original 3.9L engine runs strong with no leaks whatsoever, great mechanical condition, frame is solid, turns heads everywhere and looks so cool with the top off, all it needs is a few grands in body work and this truck will be a real show queen.
During the restoration process, the following parts had been replaced:
SS brake lines (Front and Rear)
tie rod ends
New Battery + cables
valve cover gasket
oil pan gasket
bump stops (front and rear)
rear lights
engine belt
air/fuel filter
NGK spark plugs and wires
Engine & transmission mounts
brake drums and shoes all around
brake shoes
wheel cylinders (front and rear)
brake master cylinder
universal joints (2 front shaft + 2 rear shaft)
MSD ignition coil
New Tie rods and steering coupler
rear brake hard line
All fluids have been flushed and replaced
All hoses replaced.
I'm sure there is some more information I left out.
Additionally, the truck has the following accessories:
American Racing Outlaw II wheels had been painted black, Front and rear heater, Bull bar with PIAA off-road lights, Warn lock Tuffy lockable arm rest/center console with Jensen unit installed but not wired, Original rear jump seats.
The odometer reads 25,700 but I'm sure it's not correct due to age, and will go up slightly because of the daily use.
A set of doors, replacement hood, extra windshield, a clutch kit, back up light switch, gear/transfer case shift boot, and Haynes repair manual will be included in the sale.
tie rod ends
valve cover gasket
oil pan gasket
rear lights
engine belt
air/fuel filter
brake shoes
MSD ignition coil
All hoses replaced.
