The lower tailgate hinges on my '95 80-series are not completely seized, but it's pretty hard to open/close. After a few opens, I can see that a bit of rust dust which signals (to me) they are likely quite rusty. Has anyone had this issue? Would dousing my hinges in WD-40 set me (and my tailgate hinges) free?
My truck was that way when I got it. I used generous amounts of PB Blaster and kept working it open/closed. WD 40 is not really lube. I have found PB Blaster is far superior to WD.
I also did the latches and the upper hinges as well.
Now, I regularly lube them with spray white lithium.
This is what I used. My tailgate would barely open and close with force. I sprayed this on the hinges an d worked it back and forth. I could see the the rust flooding out with the spray. My tailgate will now fall flat if i allow it. This is a great product.
I opened this thread hoping to solve my seized tailgate issue however my problem is different. My tailgate opens just fine. The problem is closing it, it seems like the extensions that act in tension to hold the load on the tailgate might be hyper-extending at the joint, causing them to lock in place and act in compression when trying to close the tailgate instead of just folding up. It takes a couple tries just to close it. Is there any adjustment that I can make to prevent this?
