Building on this thread, which describes a similar issue but no clear resolution.
My sunroof has worked perfectly up to today. I exercise it at least once a month: open/close/tilt, and blow debris out of the nooks and crannies, clear the drains annually. Never lubed it, though. But no issues.
Today I noticed the motor was really straining to get it open and closed, and ultimately, I could not get it to tilt back down and closed. I removed the glass panel. When I hit the tilt-down button, the motor makes a straining noise. The passenger side tilting mechanism moves a little, the driver size does not move at all. Pressing down on the mechanism does not help.
There is a visible component that slides fore-aft and tilts the back edge of the sunroof up with a jointed mechanism. This piece is in a rail, and I noticed that on the driver side it was frozen in place on the rail. I pushed it backwards with a screwdriver while pressing the down-tilt button, and motor labored but got the mechanism closed. It feels like that sliding part, just on the driver side, needs to be lubed. I sprayed a little lithium grease around it, but it got stuck again and needed another screwdriver assist. The sunroof is closed now, but the problem isn't resolved. This is the mechanism (not my vehicle):
For tilt, part of it slides backward, which pushes the back edge of the glass up as shown by the green arrows.
Question: how do you disassemble and lube the sliding/folding/lifting mechanism for tilt? I don't think this is a drop-the-headliner situation because the motor and gear cable seem to work - I think it's just a bound up tilt mechanism that is fully exposed with the glass removed. Could not find a how-to with pics here.
