- Joined
- Oct 12, 2006
- Threads
- 2
- Messages
- 3
- Location
- United States
Hai,
Ace Security Laminates protects your car and yourself from break in, riot situations and crude firebombs. In case of car hijacking, you get plenty of time to escape as the intruders' first instinct is to break your car window glass in order to succeed. With Ace security laminates installed on your car windows, the intruder does not succeed in breaking the window glass even by attacking the car windows with iron rods, rocks, baseball bats, sharp objects and Molotov cocktails. Our Laminates can be easily installed in all cars and models sold in India.
SECURITY
It's not where you live.. But where you drive and park! The first target area for smash and grab thieves is shopping malls! If a thief can't break into your car, they can't steal the CONTENTS, the CAR or attack YOU! No other vehicle protection system such as steering wheel locks, alarm systems or location devices can prevent a smash and grab attack. Because after all, nothing bad happens until a thief gets INSIDE your car.
SAFETY
65% of injuries in car collisions occur as a result of flying glass. With Ace Security Laminate's superior strength and unique adhesive, glass adheres to the film, dramatically reducing any flying glass. And in the event of a serious accident, Ace Security Laminate helps reduce the possibility of ejections from a vehicle through broken windows /windshields. Finally, with car jackings on the increase nationwide, Ace Security Laminate provides perhaps your only layer of protection between you and violent criminals.
99% UV REDUCTION
No other safety or security product can also protect your car's interior from the damaging effects of UV radiation. With Ace Security Laminate, you can dramatically reduce fading, cracking and destruction of your car's interior. Untreated glass only blocks 2 to 3% of the sun's damaging rays from reaching you or your car's interior.
HEAT & NOISE REDUCTION
With Ace Security Laminate installed on your vehicle, you receive the added benefit of heat and noise reduction. Interior heat build-up can be reduced by as much as 20 degrees based on external temperature; noise from the wind and road is reduced by as much as 4 decibels
SECURITY
SAFETY
99% UV REDUCTION
