I haven't checked out any DB setups in person yet, I'm still a noob and learning. A factor that I haven't seemed to stress is cost, I need to keep it dirt cheap.
In that case, consider skipping the whole dual battery idea and put your budget for this project into a single large capacity reliable battery.
I think you'll find that the battery itself is only a fraction of the costs involved in engineering your own dual battery system from scratch. Also, the more distance you have from the alternator to the remote mounted battery, the higher the wire gauge and more expensive the cable to reach it will need to be in order to get 'charge voltage' to it.
It will be interesting to see what you come up with.
I've also been studying all the differnent second battery options for awhile now (head beating against wall smiley) and was leaning towards using the second battery for all of the accessories. Now I'm leaning towards running everything off of the main battery and of course keeping it isolated from the second. It seems to me that the whole purpose of the second battery is to have it has a secondary backup. If you use it to power all of the accessories and, for whatever reason, toast your main battery...you could be walking.
I like the Odyssey design (PC1500T) accept for their terminal design and placement. They supposedly can take being discharged up to 400 times.
The Hellroaring battery isolator seems to have the best of both worlds in isolation and switching capability.
Hadn't given a thought about the alternators ability to put out enough voltage to keep the batteries completely topped off though.
Is heavier wire the answer or an alternator with higher voltage output?
You can take a look at what I have, I know there are lots of choices, depends on what you need to accomplish. I've got mine set up on a 3-way switch in the dash.
Position 1: charges both batteries when the alternator is charging - not until.
Position 2: isolates the two batteries (running off only the house battery when I don't want to drain the car battery)
Position 3: Manually connects the 2 batteries together if I need to self-jump (actually had to once, careless teenage drivers left lights on! That problem can't be fixed with wrenches TCH2FLY!!).
I use a simple solenoid, a ground interrupt switch under the hood, and a 3 position switch inside.
Actually in my set-up wrenches are EXACTLY how I can fix that problem .... I swap two cables and I'm ready to go. Not as "cool" and slightly more time consuming but will get the job done IF I every need it.
Glad you were prepared and glad you have a setup you like.
For the record I think it is fine to have that option. I do take exception to those that try to convince everyone that it is the ONLY or BEST solution .... like every modification it should be tailored to the user. We all have different needs, budgets and goals .... that is why this place is such a great resource.
Have you priced quality 00-gauge battery cables? Mount it under the bonnet using the 91 battery tray. You will thank us for this advice.
If you insist in putting your 2nd battery somewhere else then consider using dual 6v gel cells in series. Robbie did this in his system; mounting them behind the right side panel in the cargo area.
I realize you said you read the FAQ on this topic. Read it again. There is an abundance of information and opinions in there. The first thing you need to do is identify *your* objectives with the system.
Example: For my system, my PRIMARY objective was to always have a charged battery ready to start my truck anywhere, any time. If you are always in a group when you are camping in the boonies then maybe this is not a concern.
What this primary objective translates to is a system design that puts all electrical loads on 1 battery and keeps the other battery completely isolated and charged up. The next objective was to be able to use the secondary/backup battery when winching or self-jumping. These objectives were accomplished with a deep-cycle primary and a starting battery as the backup battery. A Hellroaring isolator/combiner was selected for the electronics. Proper HD fuses, connectors, and 00-gauge welding cable complete the installation. It took a long time to plan and was relatively expensive but, IMHO well worth the effort and expense for the peace of mind.
Yep, I agree. What do you need? Has to be planned ahead, cost included. I was going for a little bit of the cool factor, but when the 16 year old driver calls and says, "dad, the batteries dead, car won't start"... it's much easier for me to tell him how to flip the switch rather than swap cables. Again, part of my purpose that I actually did think about as I designed the system. Worked well once. Was it worth it all. Probably, because it could happen again I suppose.
Also mkfour, are you thinking at any time that you'd want to be able to weld by hooking up the 2 batteries? That's an option too, as long as you know how you've configured them (both fully charged at any time) and how to hook them up for welding, etc. Just one more thing to think about.
Hope you can make it to the Toyota 50th anniversary tomorrow(?) How close to Torrance are you?
